3-wire Pressure Transducer
Hi Good day, I am try to find an answer about on how to connect my 3-wired pressure transducer to an NI 9219 universal analog. NI 9219 is the only module that is available in our institution and only module that is compatible in reading pressure transducer. I'll be honored and thankful if someone can fixed my problem on how to connect my pressure transducer to NI 9219.
Message 1 of 9
(4,182 Views)
Can you share more details on your Pressure Transducer? model? link to a datasheet or user manual?
Santhosh
Soliton Technologies
Message 2 of 9
(4,180 Views)
Attached photo is the pressure transducer that I bought.
Here are the Screenshot_5.jpgSpecification:
Item Type: Pressure Transducer
Material: Stainless steel
Overload Pressure Range: 100PSI
Overload Pressure: 1.5 times rated pressure
Breaking Pressure: 3 times rated pressure
Operating Temperature: -40℃-125℃
Output Signal: 0.5V-4.5V linear voltage output
Accuracy: Within 2% of reading (full scale)
Thread: 1/8in 27NPT thread
Media Compatibility: Refrigerant, clean non corrosive oil, gas and water, etc.
Wiring Connectors: Watertight quick disconnect. Includes mating connector (standard Packard Metri pack connector) and wiring harness (pigtail).
Wiring: Red +5V. Black for ground. (sometimes green) Blue for signal output
Message 3 of 9
(4,178 Views)
Your sensor needs a 5V supply voltage , as far as I understood the 9219 spec ,this unit can't supply 5V
so you need an external 5V supply  (red and black) . the voltage out pin (blue)  and black go to the 9219
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 9
(4,094 Views)
Can you please elaborate further? i didnt get it totally especially the the color assignments
Thank you
Message 5 of 9
(4,035 Views)
What cable colors do you have on your sensor?
Since you already ask aboout the cable colours, I assume you have no engineering background.
You need a 5V power supply. You can try one of these 500mA 5V chargers, but you need to check if they really put out 5V (some do more) and usually the 5V provided is not very 'clean' , mean you migth measure some nasty hum or other stuff due to the switched power supply. Nice would be a bench lab powersupply set to 5V.
the black(or green) cable from your sensor needs to be connected to the negative powersupply and the [negative/GND/AI- ] input of your 9219 channel . the red cable need to connected to the +5V of yur powersupply and the blue to the [positive/AI+] input of the 9219.
Henrik
LV since v3.1
Message 6 of 9
(4,026 Views)
Thank you for the reply.
My sensor has Green, Black, and Red wires.
Message 7 of 9
(4,015 Views)
Greetings,
the sensor still wont read. I've the wire connection you've suggested
Message 8 of 9
(3,943 Views)
@Jeiel97 wrote:
Greetings,
Unfortunately, there is no way we could verify your connections and how you attempted to read the sensor.
Please provide all relevant information as we are limited to what you post here.
Santhosh
Message 9 of 9
(3,938 Views)
