Read multiple counters and analog inputs using the NIDAQmx ANSI C library in Visual Studio (USB-6211)
I am using an NI USB-6211 DAQ Device and I need to read 2 counters (ctr0 and ctr1) and two analog inputs (AI0 and AI1) simultaneously. Because I am controlling my motors in C in Visual Studio, I need to do that also in Visual Studio using the NIDAQmx ANSI C library. Nevertheless, I only manage to read either one counter or one analog input at a time. When I try to read two counters in the same time for example, it does not work. So my question is: Is it possible to read multiple counters and analog inputs simultaneously using the NIDAQmx ANSI C library? If yes, can you please provide me an example of program to do that?
Thank you in advance for your help.
Maxime
(1,070 Views)
Use Channel Expansion, simply add another channel to the same task.
https://tmesystems.net/
(1,061 Views)
Thanks for your response but I am using LabView, I am coding directly in ANSI C. So how can I use channel expansion in ANSI C?
(1,028 Views)
Sorry, I wanted to say: I am NOT using LabView.
(1,012 Views)
