Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
4 Channel Waveform-Output with PCI-6259
MichaGue_01
Member
06-24-2008
02:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi NG,
I'm using a PCI-6259 with LabVIEW 8.2.1. The 6259 has 4 analog outputs and the manual tells the following maximum update rates:
Maximum update rate
1 Channel
0
Kudos
Message
1
of 2
(2,862 Views)
Reply
Re : 4 Channel Waveform-Output with PCI-6259
JB
Trusted Enthusiast
06-24-2008
03:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Continued
here
0
Kudos
Message
2
of 2
(2,858 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
