+5V USB 6210
i have a little problem with the USB 6210. I want to use the +5V Pin (I/O connector) as supply for a smal IC. But i can't measure the 5V? In the doc i found this note:
+5 V Power -- These terminals provide a +5 V power source or can be used to externally power the digital outputs.
How to change the direction (Input/Output)? I use .NET but i couldn't find something in LABView, too.
Can someone help me?
Regards
Steven
(4,494 Views)
Hi Steven,
in which doc did you have a look? The right user manual is the following:
NI USB-621x User Manual
http://digital.ni.com/manuals.nsf/websearch/5452CD6A491AC0288625757B0065EA32
On page 3-3 you find the chapter concerning the 5V power supply.
"Because the USB-621x devices are bus powered, there is a 50 mA limit on the total current that can be drawn from the +5 V terminals and the digital outputs. The USB-621x monitors the total current and drops the voltage on all of the digital outputs and the +5 V terminals if the 50 mA limit is exceeded."
Kind Regards,
Vanessa
AE
(4,472 Views)
Hi Vanessa,
thanks for your replay. Yes this was my fault. I didn't look at the total current. I disconnect some digital outputs and now i can measure the +5V at the terminal.
King Regards,
Steven
(4,468 Views)
Hi Steven,
thank you for your fast answer.
If you have further questions feel free to come back to me.
Kind Regards,
Vanessa
(4,466 Views)
Thanks for this offer.
Steven
(4,464 Views)
