5VDC to 10VDC with USB-6009
Is there an easy solution to change the 0-5V signal of the USB-6009 to a 0-10V signal?
For the automation of our pilot we need two analog outputs of 10VDC. Are op-amps a good solution?
Greets,
Dominic
(3,692 Views)
What are you trying to get 10 volts into or out of?  Analog output?  Digital I/O?
(3,682 Views)
2x 10V DC analog outputs (for an ozone generator and a ballast of a UV lamp)
So I need to find a way to transform the 2x 5V DC analog outputs of the USB 6009 to 2x 10V DC analog outputs.
(3,678 Views)
This just a reference/signal voltage, or is it going to be used to actually power the device?
If it's low-current signal voltage (a few mA), an opamp circuit will do fine.
For something with a little more grunt, you might want to consider a programmable power supply.
Other option is to upgrade to a 621x-series DAQ, those can output 0-10v right at the AO terminals.
(3,670 Views)
