6008 which linux distribution
I'm looking to migrate a piece of hardware to use the 6008 multifunction DAQ. In the experience of other users, which Linux Distribution and Version is most compatible with the drivers?
Ben
(4,053 Views)
Hi Ben,
OpenSuSE, Mandriva or Red Hat Enterprise has shown to be the most compatible, although due to the closeness to RedHat CentOS has become quite a popular choice as well.
More information on supported Linux Distributions can be seen here
(4,035 Views)
Thanks for that, I went with OpenSuse 11.2 and the drivers installed with a few minor tweaks. The C examples compile and run fine however if I try and load the libnidaqmxbase.so library using ctypes in python, I always get the error "Unable to load libniCPUlib.so from /usr/local/lib/labview-2010/libniCPUlib.soAborted" (Ignore capitalisation)
If i try and load libniCPUlib.so directly (again ctypes in python) I get the error that _ZNSt15_List_node_base4hookEPS_ is an undefined symbol which "nm -o /usr/lib/* 2>/dev/null | grep _ZNSt15_List_node_base4hookEPS_" shows exists in /usr/local/lib/liblvrt.so
can you shed any light on what's happening here?
(3,934 Views)
To answer my own question, it seems that libniCPUlib.so needs "/usr/local/lib/liblvrtdark.so.10.0" loaded to work but ctypes wasn't loading this automatically, therefore to get the library to work in ctypes you have to do something like:
import ctypes
ctypes.CDLL("/usr/local/lib/liblvrtdark.so.10.0" , mode=ctypes.RTLD_GLOBAL)
ctypes.CDLL("/usr/local/lib/libnidaqmxbase.so")
(3,929 Views)
