6250 multi channel
Hi, I'm using a DAQ card which is a M-series PCI 6250.
It's not capable to do multi-channel task. However, the sources are at least two of them.
Is it any possible to obtain the two digital signal source in turns, like
time     data
time(1)    x1
time(2)    y1
time(3)    x2
time(4)    y2
And then I can interpolating them.
(2,955 Views)
Hi Cedrick
Firstly what software are you using to acquire your data as it is actually very easy to acquire from multiple channels at the same time. Please look at this forum which discusses how to do this in LabVIEW. If you let me know what software you are using I will try and point you towards some examples.
Regards
Rich
NI | UK
(2,931 Views)
(2,930 Views)
Thanks!
It helps me a lot!
(2,914 Views)
