6259 Analog input precision
I 'm using for the first time a USB 6259 DAQ.
I made the acquisition of further analog signal triggered by an analog signal with the Vi express.
Sample rate = 40k
number of sample  = 1600
I should have a 25µs precision measurement over 40ms time measurement.Right?
If I compare my acquired results with a scope I can have a delta higher than 0.1 ms .
how can I improve the precision of my acquisition?
Why I cannot  do the same with a 100K sample rate with 4000 points.Is it due to the buffer size's limitation?.
Thanks for your help
Philippe
(3,338 Views)
Hello Popo,
There is a sub-VI in your project named "untitled" that isn't included into it. I can't see anything bad in your diagram, so I think the problem should be into this sub-VI.
Another thing you could try is to put a "wait until next ms multiple" inside your while loop...
Best Regards,
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(3,299 Views)
