Dear Reader
I tried to synchronize the start of two devices using a RTSI-Signal.
The Master-Device does the sampling, the Slave-one not. Could anyone please tell me what's going wrong?
Pascal
//PCIe 6259 (Dev1): AO master, export StartTrigger to RTSI0
error = DAQmxCreateTask("",&ao6259TaskHandle);
error = DAQmxCreateAOVoltageChan(ao6259TaskHandle, "Dev1/ao0", "", -5.0, 5.0, DAQmx_Val_Volts, "");
error = DAQmxCfgSampClkTiming(ao6259TaskHandle, "OnboardClock", 1000.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 10000);
error = DAQmxExportSignal(ao6259TaskHandle, DAQmx_Val_StartTrigger, "RTSI0");
error = DAQmxWriteRaw(ao6259TaskHandle, 10000, false, 10.0, dataBuffer, NULL, NULL);
//PCI 6733 (Dev2): Slave device (only triggered)
error = DAQmxCreateTask("", &ao6733TaskHandle);
error = DAQmxCreateAOVoltageChan(ao6733TaskHandle, "Dev2/ao0", "", -5.0, 5.0, DAQmx_Val_Volts, "");
error = DAQmxCfgSampClkTiming(ao6733TaskHandle, "OnboardClock", 1000.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 10000);
error = DAQmxCfgDigEdgeStartTrig(ao6733TaskHandle, "RTSI0", DAQmx_Val_Rising);
error = DAQmxWriteRaw(ao6733TaskHandle, 10000, false, 10.0, dataBuffer, NULL, NULL);
DAQmxGetExtendedErrorInfo(errBuff,2048);
error = DAQmxStartTask(ao6259TaskHandle);
