RTSI Trigger (DAQmx & C++)
Dear Reader
I tried to synchronize the start of two devices using a RTSI-Signal.
The Master-Device does the sampling, the Slave-one not. Could anyone please tell me what's going wrong?
Pascal
//PCIe 6259 (Dev1): AO master, export StartTrigger to RTSI0
    error = DAQmxCreateTask("",&ao6259TaskHandle);
    error = DAQmxCreateAOVoltageChan(ao6259TaskHandle, "Dev1/ao0", "", -5.0, 5.0, DAQmx_Val_Volts, "");
    error = DAQmxCfgSampClkTiming(ao6259TaskHandle, "OnboardClock", 1000.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 10000);
    error = DAQmxExportSignal(ao6259TaskHandle, DAQmx_Val_StartTrigger, "RTSI0");
    error = DAQmxWriteRaw(ao6259TaskHandle, 10000, false, 10.0, dataBuffer, NULL, NULL);
//PCI 6733 (Dev2): Slave device (only triggered)
    error = DAQmxCreateTask("", &ao6733TaskHandle);
    error = DAQmxCreateAOVoltageChan(ao6733TaskHandle, "Dev2/ao0", "", -5.0, 5.0, DAQmx_Val_Volts, "");
    error = DAQmxCfgSampClkTiming(ao6733TaskHandle, "OnboardClock", 1000.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 10000);
    error = DAQmxCfgDigEdgeStartTrig(ao6733TaskHandle, "RTSI0", DAQmx_Val_Rising);
    error = DAQmxWriteRaw(ao6733TaskHandle, 10000, false, 10.0, dataBuffer, NULL, NULL);
    DAQmxGetExtendedErrorInfo(errBuff,2048);
    error = DAQmxStartTask(ao6259TaskHandle);
(2,971 Views)
Dear pboehi,
please check the following links if the provided solutions solve your request as well.
Carsten Sprung
What is the procedure to initialize and use RTSI clock (7) signal?
http://forums.ni.com/ni/board/message?board.id=180&message.id=15167&requireLogin=False
How to synchronize scan clock for PCI-6110 devices with LabWindows
http://forums.ni.com/ni/board/message?board.id=180&message.id=10819&requireLogin=False
Import a signal for synchronization of onboard clock
http://forums.ni.com/ni/board/message?board.id=250&message.id=11555
How can I send a pulse to a RTSI line with a software command?
http://forums.ni.com/ni/board/message?board.id=180&message.id=5641&requireLogin=False
Still struggling with RTSI
http://forums.ni.com/ni/board/message?board.id=180&message.id=2254&requireLogin=False
(2,942 Views)
