6281 analog outputs
Hi:
Hi:
I want to produce a simple analog voltage outpot on a with a pxi-6281 card (pxi). I'm using a 50pin cable at the 1349
connector on the scxi chassis. I'm using pins 20 & 21 and the ground is 23 (I hope this is correct). All of this is done
with SignalExpress.
Hi:
with SignalExpress.
I'm sending a 1Hz signal (-1 to 1 Volt). I can't see anything with the oscilloscope.
Hi:
with SignalExpress.
I can't find what I'm doing wrong. The only thing that I see as a problem, when I am doing signal inputs (1314 to a 1520),
normally I "activate" the channel on the proper card (the proper 1520). In this case there is no activate for the outputs, all
the channels (for the 6281) available are inputs.
Hi:
with SignalExpress.
Any ideas?
(3,305 Views)
Have you tried a DC output voltage with MAX. That way you can check the pins with a multimeter so you know if the hardware is ok.
Felix
(3,304 Views)
According to this, your pinouts look correct.  Trying Felix's suggestion is worth a try, maybe disconnecting the 1349 from the SCXI chassis and trying the measurement may be helpful.  Or, if you have a breakout box (CB-68) you can hook up directly and bypass the SCXI hardware.  Here is the pinout for the 6281 if you choose to use this.
Kyle A.
Senior Applications Engineer
(3,271 Views)
