6421 driver
I have an USB-6421 DAQ but I need to install a driver to use in windows 7. Where can I find it?
Thenk you,
(512 Views)
Hi there,
You need the install the DAQmx driver. Version 20 is the last version to support Windows 7.
You can find the driver download here!
(488 Views)
And unfortunately, USB-6421 is first supported in NI-DAQmx 2024 Q3 and hence is not supported in Windows 7.
Reference: NI Hardware and Software Operating System Compatibility
Unsupported means NI R&D has not validated it thus it is not guaranteed that the driver will work properly.
https://tmesystems.net/
(469 Views)
