6601 is not reckognized by nilsdev
Hello,My PCI 6601 is not reckognized by the NILSDEV.
I have  CEntos 6.4, 32 bit
memory is limited to 4 Gb during the load
Outputs:
>milsdev
returns nothing
System:
>uname -a   2.6.32-358.14.1.el6.i686 #1 SMP Tue Jul 16 21:12:30 UTC 2013 i686 i686 i386 GNU/Linux
PCI card:
>lspci -a
04:01.0 Unassigned class [ff00]: National Instruments PCI-6601 (rev 01)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 17
Region 0: Memory at f7102000 (32-bit, non-prefetchable) [size=4K]
Region 1: Memory at f7100000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: nidaqmx_nidaq2
NI modules:
>lsmod
nimxpk                 33668  0 nimru2k               427718  1 nipxirmk              115060  1 nidimk                330397  5 nimru2k,nipxirmknimsdrk               230683  0 nidmxfk               373198  1 nimsdrknimxdfk               493567  5 nimru2k,nimsdrk,nidmxfknimstsk                77966  2 nimsdrk,nidmxfknimdbgk               379979  7 nimru2k,nimsdrk,nidmxfk,nimxdfk,nimstskniorbk                 97586  8 nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgknipalk               1224464  14 nimxpk,nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk,niorbknikal                  71410  1 nipalk
What could be missing?
thank you
(4,283 Views)
strader,
CEntos is not a version of Linux officially supported (see this KB: http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument).  Have you successfully used this device on another distribution?
James K.
(4,254 Views)
I know that it is not officialy supported, but it is de-facto a Read Hat clone.
Previously, I have installed Centos on another mashine and it worked well with and old PCI MIO 16 card (6601 is not shown on that machine either).
I am wondering at what point the 6601 card recognition fails. The card itself is reckognized in the Windows, so it should not be a hardware issue.
(4,250 Views)
strader,
What version of the DAQmx base driver are you using?
Check out this forum post, it seems to be a similar issue that was resolved using DAQmx base and lsdaq:
http://forums.ni.com/t5/Multifunction-DAQ/nilsdev-returns-nothing-Debian/td-p/775514
James K.
(4,232 Views)
This is the continuation of the same proble.
We have installed REd Hat 32 bit on this computer:
Red Hat Enterprise Linux Workstation release 6.4 (Santiago)
Labview  was installed without problem.
The Nidaq version is 8.0.2.f0 + drivers updated using updateNIDrivers.
card is listed:
    Flags: bus master, medium devsel, latency 32, IRQ 17
However, nilsdev still see nothing  and nidaqmxconfig does not return anything except:
[DAQmx]
MajorVersion = 8
MinorVersion = 0
this is now supported Linux version. Still, I cannot communicate with the PCI-6601.
(4,157 Views)
Does lsdaq return anything?
James K.
(4,146 Views)
if you mean Base then  no, and  6601 is not supported  by Base.
(4,142 Views)
