6722 and SuSE Linux 10.3
I'm trying to use a 6722 with SuSE Linux 10.3. NI-DAQBase supports SuSE 10.3, but doesn't offer 6722 support. Has anyone successfully used NI-DAQmx 8.0 on SuSE 10.3, or know if there'll be an official release of NI-DAQmx that supports SuSE 10.3? Thanks very much.
(3,161 Views)
Hi niusernicholas,
You may find this link helpful, it sounds like a set of instructions from another user on how to get DAQmx 8.0 installed on SuSE 10.3.
http://forums.ni.com/ni/board/message?board.id=170&message.id=331638&query.id=7450#M331638
Hope this helps
Chris
(3,144 Views)
Thanks for your reply. It seemed to work until I tried installing NI-DAQmx 8.0 when I got this error:
******************************** ERROR ****************************************
* It appears that your system is running a 64-bit version of Linux.  This     *
* product only supports Linux x86 32-bit systems.                             *
I suppose this means that I need to run the 32-bit SuSE and not 64-bit? Do you think there'll ever be 64-bit support? Thanks!
(3,131 Views)
This may be something we support in the future, but I have no idea when that might be.
Chris K
(3,106 Views)
