8 dc analog outputs with NI 6713
I am new to labview. I would like to generqate 8 dc analog outputs with NI 6713, would you please give me some advices about it?
Any advices are greatly appreciated.
Thanks.
(2,578 Views)
Yuan,
I would advise you to examine AO Update Channels.vi. This VI is available in the following location:
Functions >> Data Acquisition >> Analog Output
With AO Update Channels.vi, you will be able to update the values of all eight channels simultaneously. I have attached a simple example, which demonstrates the use of this VI.
Good luck with your application.
Spencer S.
(2,578 Views)
