9133 "National Instruments" screen on boot-up - no windows screen
Got the above screen on boot up several times on a cDAQ running Windows embedded 7; did not get expected windows screen. After several attempts of power off than on and pressing reset button, windows screen with application icon finally appeared. What does this mean? 😧
(2,624 Views)
It looks like i've the same problem; i found this article to repair / re-install windows 7e
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DkdeCAC&l=en-US
But now i'm stuck in the re-installing part : -(
(2,562 Views)
Seems that your controller is not able to POST successfully, I am inclined to advice you to contact your local NI representatives to have it repaired.
You may try to get into the BIOS to see if the harddisk/RAM is properly detected if you'd like to investigate more.
(2,551 Views)
Do you believe both screens are indications of the same problem? My issue (top screen) is that it displays the National Instruments screen with LOGO. The bottom screen depicts a "Windows Embedded 7 Standard" screen. Is there possibly an error log somewhere that I could send to NI, or possibly some type of Scan disk tool to determine any drive issues? The system is now working correctly but I should think it will happen again? Thanks!
(2,544 Views)
I had your problem first and i tried to boot with an external medium, after a few restarts he enters the reinstalling-mode from my DVD or USB. But it gets stuck there.
I've also tried to restart a 10 times without external boot without succes
(2,536 Views)
I am not sure about that to be honest, as a system that is unable to POST could be due to multiple reasons.
(2,522 Views)
