9206 DO
i have a Ni 9206 how can connect the DO terminal?
DO -> Load -> Com board?
(1,713 Views)
NI 9206 is a C-series voltage input module. could you please double-check the model number?
Only 94xx series are DI/DO cards -https://www.ni.com/en-us/shop/category/digital-io.html?productId=118123
Santhosh
Soliton Technologies
(1,678 Views)
Hello dadebo,
The DO is sourcing and is connected using pin 18 (DO) and pin 17 (COM).
Just take into consideration that the DO High is 3.3V and 75 micro Amps
Saludos.
(1,648 Views)
(1,530 Views)
