01-06-2008 10:29 PM
01-07-2008 02:10 PM
Hello NVMS,
This is a peculiar behavior indeed. I have looked into the issue and I cannot find anything that explicitly reports the same symptoms in relation to the DAQmx 8.5 or the USB issue itself.
"Is the problem that there actually is a task still running? If so, is there a way to forcibly stop any tasks running inside the device?"
When you reset your device, the tasks that are currently running should stop as well. You can verify this by running a basic task in MAX and resetting your device. You will notice that the task stops running upon reset.
You could attempt to manually stop the task in code by referencing the task and using the clear task method in .Net 2.0, however resetting the device should do this.
I have a couple questions regarding your system setup that I am curious about, that hopefully will also lead us to a good solution.
1. What is the other USB device that you are disconnecting when this behavior occurs?
2. When you disconnect the device, are you disconnecting the device by physically removing the USB connector or are you disconnecting the device through your operating system settings?
3. Does this occur with any additional USB device, or only a specific one?
4. Do you have any other NI DAQ devices that show these symptoms?
5. What operating system are you using?
6. Are you using the USB slots on the front of your computer, or the USB slots on the rear backplane of the computer?
The USB slots at the front of the computer are simple extensions for convenience and are meant for simple USB devices such as USB drives and so on. For high bandwidth devices such as DAQ boards, it is recommended to use the USB slots located directly on the backplane of the motherboard.
From what you've provided so far it seems like this issue is related to how the operating system, the USB bus, and the USB devices are interacting with one another. See if you can answer the above questions, and include any additional information you think of and we will try to work through it. Thanks!
01-07-2008 07:35 PM
01-09-2008 07:56 AM
Hello NVMS,
Thank you for getting back to me with more information. The behavior you describe points my thoughts to a USB bus issue being the culprit. You mentioned that using a standalone USB hub could be a potential solution. Have you tested this theory? I would be interested to know if this is the case.
You mentioned that you are physically removing the USB storage drive. Have you attempted to disconnect/disable the storage drive through the Windows interface before physically removing it? “Pulling the plug” on a USB device without properly disconnecting it in software can cause the OS and USB controller to behave strangely.
Can you attempt to set up the USB devices on a different system? This could help us determine if there is specific hardware involved with this issue or not.
Another test would be to set up a continuous acquisition task on the USB 6008 and see if you can replicate the behavior across all of our devices.
Finally, if your system supports it, see if you can connect the USB storage device to a different port than the 9215A. This solution is similar to using a USB hub, but without the extra power consumption.
If we can narrow down the source of the behavior to specific hardware we can take further action on this issue.
