9403 cDAQ change direction in run time.
Hello.
I am looking at the property nodes but cannot find anything. How can I change the pin direction from I to O and vice versa?
Bill.
(4,224 Views)
Hi Bill,
You can change that by clicking on the property node and selecting "Change all to write".
Thomas N.
(4,182 Views)
Hello.
Which property node? I cannot find any appropriate one that can set the input or output.
Thanks.
(4,164 Views)
You set the direction with the DAQmx Configure Channel function.
(4,160 Views)
