Error -200284 occurred at DAQ Assistant
While reading a PWM signal from NI 6723 PIN number 41. Am getting a error "Error -200284 occurred at DAQ Assistant" . Can you please suggest how to overcome this error.
Possible Reason(s):
Some or all of the samples requested have not yet been acquired.
To wait for the samples to become available use a longer read timeout or read later in your program. To make the samples available sooner, increase the sample rate. If your task uses a start trigger, make sure that your start trigger is configured correctly. It is also possible that you configured the task for external timing, and no clock was supplied. If this is the case, supply an external clock.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Thanks in advance
(4,658 Views)
  Can anyone please solve my problem
Thanks in advance
(4,652 Views)
<Sarcasm>Yep, we can magically solve your your problem without knowing anything about your code.<\Sarcasm>
Please share some of your code.  Since you are using the DAQ Assistant, we will need the actual VI.
(4,642 Views)
