05-06-2007 05:17 PM
05-07-2007 05:45 PM
If you start from the "Multi-function-ctr Retrigg Pulse Train Generate for AI Sample Clock" (which is the best place to start) you should just have to add the code from the "Cont Gen Voltage Wfm-Ext Clk.vi" and specfiy the same clock source as the AI task (the counter output). You should not need the 6602. If you want us to take a look, please attach your code, or detail what settings you are using.
Cheers,
Andrew S
05-12-2007 02:59 PM
