03-17-2007 11:43 PM
03-18-2007 09:41 AM
03-18-2007 09:04 PM
03-19-2007 08:10 AM
You either wired a constant to the data input or not. And I mean wiring on the block diagram. If you do have the DAQ Assistant wired as below, then it should work just like in MAX. Did you configure the DAQ Assistant for on-demand timing? Is there anything else in your program?I didn't add any line to 6008. In LabView, I give const 2 as a input voltage(2V).
03-19-2007 11:18 PM
03-20-2007 10:09 AM
