Multifunction DAQ
AI with cDAQ-9181 on linux
This topic has been opened in 2016, is there anything new since then ?
I have bought a cDAQ-9181 and I am trying to collect data from AI of a 9203 Current Module
on Linux.
I spent 2 days on www.ni.com/download and www.ni.com/support but coudln't find any solution.
Is there any Python, C or C++ Example code to get the data?
Henry.
Message 11 of 13
(781 Views)
NI DAQmx driver library is not supported on Linux. The best National Instruments could come up with was to suggest that I run virtual machine with Windows OS under Linux and somehow transfer data from windows to Linux.
Message 12 of 13
(773 Views)
The latest available version of Linux drivers library NI DAQmx is at https://www.ni.com/en/support/downloads/drivers/download.ni-linux-device-drivers.html . The file http://download.ni.com/support/softlib//MasterRepository/DriverUpdates.zip lists all supported devices. cDAQ-9181 is not on the list, so the National Instruments does not support under Linux.
Message 13 of 13
(712 Views)
