Multifunction DAQ
AIGATE, AOGATE, SISOURCE, UISOURCE with Labview
Why these signals are not configurable with Labview6.1?
(signals from NI PCI-6110/6111)
(2,607 Views)
Greetings,
The following KnowledgeBases discuss using AO Clock Config.vi and AI Clock Config.vi to configure the UISOURCE and SISOURCE signals, respectively:
Selecting an External Source for the UISOURCE Signal
How Do I Use SISOURCE as the External Timebase for the STARTSCAN Signal?
With regards to the AOGATE and AIGATE signals, you will need to use AO Trigger and Gate Config.vi and AI Trigger Config.vi, respectively.
Good luck with your application.
Spencer S.
(2,607 Views)
