Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
AIGATE, AOGATE, SISOURCE, UISOURCE with Labview
remifab
Member
11-11-2003
12:02 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Why these signals are not configurable with Labview6.1?
(signals from NI PCI-6110/6111)
0
Kudos
Message
1
of 2
(2,601 Views)
Reply
Re: AIGATE, AOGATE, SISOURCE, UISOURCE with Labview
Spencer S.
Active Participant
11-12-2003
06:37 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Greetings,
The following KnowledgeBases discuss using
AO Clock Config.vi
and
AI Clock Config.vi
to configure the UISOURCE and SISOURCE signals, respectively:
Selecting an External Source for the UISOURCE Signal
How Do I Use SISOURCE as the External Timebase for the STARTSCAN Signal?
With regards to the AOGATE and AIGATE signals, you will need to use
AO Trigger and Gate Config.vi
and
AI Trigger Config.vi
, respectively.
Good luck with your application.
Spencer S.
0
Kudos
Message
2
of 2
(2,601 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
