Multifunction DAQ
AMUX-64T and MAX
Hi!
I have several applications I developed in LabWindows/CVI for NT/2000/XP.  They've worked fine until recently.
My last XP computer has been replaced, and I can't get the anything to work with Win7 and TradDAQ7.5.
I have two PCI cards, 6034E connected to an AMUX-64T, and a 6052E connected to a BNC2090.
MAX lets me set everything up correctly, but my readings are garbage.
I'm not sure what to do at this point.
Carl
(4,378 Views)
Hey TheFish,
Using Traditional DAQ with a modern system can be tricky. Only the 32 bit version of Windows 7 is supported in tDAQ.
https://www.ni.com/en/support/documentation/compatibility/22/traditional-ni-daq--legacy--windows-vis...
If you are using a 64-bit machine, I suggest transitioning your code to the NI-DAQmx driver which still supports the PCI cards that you are using. The following guides outline some of the major differences between tDAQ and DAQmx.
https://www.ni.com/en/support/documentation/supplemental/06/transition-from-traditional-ni-daq--lega...
http://digital.ni.com/public.nsf/websearch/7759B0D2A8A392DF86256D21001B452E
Libby B.
Applications Engineering Specialist - RF Wireless
(4,301 Views)
