AOonePoint Example for PCI-6711 does not output 2.5 Volts. What's wrong?
Hardware:6711
Software:only VB, I am not using Measurement Studios
NIDAQ Examples for PCI 6711 - VBasic Folder
When I measure the output (DAC0OUT pin)on a scope while running AOonePoint Example I see a voltage spike and then the output is 0 Volts when it should be 2.5 Volts. I have a similar problem with the WFMSingleBufASync example not outputing anthing (I posted a question on the 25th), however WFMSingleBufSync does seem to output properly. I have tried writing my own program using the AO_Vwrite function with the same result. Are there any common solutions to this or is there any troubleshooting information for the Example files besides the NI-DAQ Examples On-Line Help and Function Ref
erence Help?
(2,376 Views)
Nevermind, I found the problem
(2,376 Views)
