AT-MIO-16E-10 & PCI-6110E do not pass Test Resources function under MAX 2.2
My AT-MIO-16E-10 & PCI-6110E will not pass the Test Resources function under MAX 2.2. Everything looks configured correctly. What now?
(2,532 Views)
Have the boards ever worked in this computer? There are some suggestions for fixing this issue at:
http://digital.ni.com/public.nsf/websearch/01F6913CDF473BFF86256AE2007D92B3?OpenDocument
Check to see if they show up properly in the Windows device manager. Sometimes a bad installation of NI-DAQ can result in similar errors. If multiple copies of NI-DAQ have been installed on the machine, possibly one form LabVIEW and one from a separate NI-DAQ installation, then this can result as well. If this is the case you will need to uninstall NI-DAQ and make sure LabVIEW is not set to install the drivers and then install NI-DAQ 6.9.3 from our website.
(2,532 Views)
