Problem with Virtual Channels in Data Neighborhood: DMA?
I have an AT-MIO-16XE-50 on a machine running NT 4.0 (latest service packs and updates). In MAX (NI-DAQ 6.9.3), the board passes the tests. I can monitor each channel & they read correctly. If I add virtual channels and try to test those, I do not get any data. I get an error 10455 at AI Config. I believe this means that no DMA channel is available. I haven't been able to get any of the three possible DMA channels working. There don't appear to be conflicts, but when I try to set the DMA channel, the system hangs during the DAQ test. Can the virtual channels work without DMA & are there any possible solutions to using DMA? Thanks.
(2,638 Views)
Since the card passes the tests in MAX, and since you are able to read data, I would suggest that you check the virtual channel configuration. Also, try testing the card on another PC, if possible.
RamziH.
(2,638 Views)
There isn't much to configure in the virtual channels! I have the correct device and channel number & type of channel. The channel configuration on this PC has been identical to the channel configuration for other cards on other PCs in the lab. I have tried reading a K-type Thermocouple channel and an LVDT channel without success. Not even a simple analogue voltage channel works!
Given the error number, I think the fact that I didn't specify DMA is what is going wrong right now.
Testing it on another PC sounds like a good idea--thanks for the suggestion.
I am also going to try once more to uninstall & then reinstall the card.
(2,638 Views)
