AT MIO-16E-10 card not responding
My LabView test system with this DAQ card, stopped working one day. The program would just hang when started. I checked the hardware through Measurement & Automation Explorer and the card shows up fine. The resources check out with control panel in Windows. But if I try to run the View Resources or Test Panel, Explorer hangs and I have to CTRL-ALT-DEL. In Windows Control Panel, there are no conflicts reported.
Suspecting the card, I removed it and tried it in another computer. No problems, the card works fine when both viewing the resources or running the Test Panel.
It looks like a software problem, but I haven't changed anything on the system and it worked fine before. My NI-DAQ drivers are at 6.9.3f3 and M&AE is 2.20.3010
. The system with problems is Win95.
Any ideas?
(2,750 Views)
Well, the card is fine cause it runs well on another machine. You can try uninstalling and re-installing the driver (if you have not done that already). Also, you can check the card out on another win 95 system and see if it works. I believe uninstalling and re-installing the driver will fix the issue.
RamziH.
(2,750 Views)
Uninstalling and re-installing the driver didn't do it. There was more than one installation of the drivers on the system, so I tried to delete them all. I also remove all NI software from the system to start from scratch, but I still have the same problem.
Before I completely wipe the system and upgrade to Win98, is there any files on the system I should look for multiple copies of that may be causing the problem?
(2,750 Views)
