I am having a problem running a daqpad 6508 in a heavy i/o envirnment. This problem seems to be platform dependant, and I'm wondering if there is some way I can slow the Daqpad's usb timing so it doesn't freeze.
The problem is this: when I run an i/o heavy application (proprietary software using the latest Nidaq drivers) using the 6508 on my 1.3 ghz Dell (win2k) I have no significant problems. However, when I run the same application with the same OS on an embedded platform, the application freezes consistently. The embedded platform is a 500 mhz K6 running on a ALI1541 chipset. Is it possible that the 500 mhz is just too slow to adequately handle USB timings of this nature? or is there some way I can adjust my device so it
runs slower?
--sa
