Hi
I am using the above card for acquiring data simultaneously on 4 channels. I have written both labview as well as Visual basic codes for this. I see that the maximum sampling rate given for the card (100 kS/s) is shared between the channels - I get maximum of 25 kS/s. I am acquiring photodiode signals detecting laser pulses with repetition rates ranging from 10 Hz to 100 kHz. I want to acquire 500 scans (points) per each laser shot and this, along with the maximum allowed sampling rate restricts my signal frequency to 50 Hz. I am using software triggering (stop) with Channel 4. I can change the number of pulses to acquire (with 50 Hz or lower)
I have the following problems:
1) Even with 50 Hz or 25 Hz signal repitition rate, the program (Visual Basic) does not acquire all the pulses I select.
2)It often gives Error :-10846 suggesting that I should either increase the buffer size, reduce the rep.rate, reduce the acquisition rate or reduce the tasks that my PC is undertaking. I am using a P-II with 64MB RAM. I know it is old š I tried with changing buffer size but it did not work. I cannot reduce the repetition rate or acquision rate for my application.
3) the labview program does not give an error but it also does not acquire all the pulses I select.
4) The problem gets worse when I try to write the data to a file.
I am using the acquisition program (both VB and labview) to simulate an oscilloscope. Is this causing the trouble? I am attaching my codes here. The file-writing part in VB program is commented out.
Thanks for your help
Rajeev
