How to eliminate voltage trigger using Synchronized 6115 with PLL.VI
I have installed two PCI 6115 boards in my PC. In order to syncronised both boards i use a VI called Syncronized 6115 with PLL. The VI works well but the problem is now that it has to be triggered by a certain level of voltage. I don't need it to be triggered because i've already pasted the whole VI in a case structure which can activate the VI with a push of a button. Could someone who's familiar with this VI please send me the solution or any other solution to synchronize both boards without using any trigger?
Mfg,
Anas
(2,865 Views)
Hi Anas,
The example VI you specified indicates it can only be used with PXI-6115. From what I understand, the PLL circuit is not available on PCI-6115. If you're trying to synchronize two PCI-6115 boards, take a look at the attached LabVIEW shipping example involving the RTSI bus. This program works with the PCI-6115 device as well.
Lesley Y.
(2,845 Views)
