AT MIO 16XE-50
I am trying to install an AT MIO 16XE-50 DAQ card in windows 2000 system but cannot set any resources (Base Address, DMA, IRQ) because they are not listed.  Have installed the drivers via Manual entry in "Add/Remove Hardware" and can see the device in both the Device Manager and in MAX.  I can set the mode to RSE etc. but cannot set Base Address, DMA & IRQ because they are not listed and there is no "Modify" button.
(3,280 Views)
Hi Stan,
What drivers are you using and what version are they?
Jas.W
Jason W.
National Instruments UK & Ireland
(3,260 Views)
I am running LabBVIEW v6.0.2 under Windows 2000, with the DAQ drivers shipped with it (MAX v2.0.3.6, NI-DAQ v6.8.0f9).  These work perfectly well with this card under Win XP and Win NT.  The drivers also work O.K. under Win2000 with PCI cards.
To cut a long story short I need to use the MIO hardware on the Win2000 PC.  I can update the DAQ drivers if necessary.
Stan
(3,254 Views)
Hi Stan,
The latest version of the DAQ drivers that support LabView 6.0.2 is Traditional NI-DAQ driver 7.1, which is available from the following link:
http://joule.ni.com/nidu/cds/view/p/id/106/lang/en
Try installing those drivers and see if the device works correctly.
Kind Regards,
Jas.W
Jason W.
(3,212 Views)
