06-25-2008 09:29 AM
06-26-2008
11:49 AM
- last edited on
10-06-2025
07:59 AM
by
Content Cleaner
Hi Cartagena!
Are you interested im buying a card that can give you Analog output signals?
If thats the case, you need to know what are the parameters you need in terms of voltage, current, resolution and then based in all that choose the card that suits your needs the most. If you are in Mexico and would like to receive personal attention call free to 018000100793 and ask for a sales representative.
If you want to check the cards, you can consult the following link:
https://www.ni.com/es/shop/data-acquisition.html
And select the Analog Output section to choose from it.
Have a great day!! 🙂
06-27-2008 09:40 AM
06-27-2008 09:47 AM
07-24-2008
10:44 AM
- last edited on
10-06-2025
08:00 AM
by
Content Cleaner
Hi Cartagena!
LabVIEW has a lot of functions to achieve what you intend to do, and it also includes examples. If you want to generate an output from your card you can check the following:
1.- Go to Find Examples in the menu at Help»Find Examples
2.- In the search tab input DAQ.
3.- Select one of the examples according to your needs.
If you want to send me your code and explain what are your needs, i can try to help you.
By the way, if you feel more confortable writing in spanish, feel free to do so!
I hope this information helps you, i wish you a great day! 🙂
