About obtainig an output signal in order to send it to a pressure regulator in a close loop
Hi Cartagena!
Are you interested im buying a card that can give you Analog output signals?
If thats the case, you need to know what are the parameters you need in terms of voltage, current, resolution and then based in all that choose the card that suits your needs the most. If you are in Mexico and would like to receive personal attention call free to 018000100793 and ask for a sales representative.
If you want to check the cards, you can consult the following link:
https://www.ni.com/es/shop/data-acquisition.html
And select the Analog Output section to choose from it.
Have a great day!! 🙂
(3,283 Views)
Hi:
I have an NI USB-6229 Multifunction I/O. The problem that I have is writhing the labview program because I dont know exactly how I can make that the voltage signal between 0-10V obtained from a PID can be processed and understand in order to make a physical task ussing a pressure regulator. I would like to know what commands can I use in order to give an output from the DAQ to a pressure regulator. This is for educational purpouse, Im novice using labview. If you think that you can revice my program just let me know because I need to finish this as soon as possible.Thanks for all your help.
Sincerely
Alexander Cartagena
Student Researcher
School of Aeronautics and Astronautics
Purdue University
(3,266 Views)
Hi Cartagena!
LabVIEW has a lot of functions to achieve what you intend to do, and it also includes examples. If you want to generate an output from your card you can check the following:
1.- Go to Find Examples in the menu at Help»Find Examples
2.- In the search tab input DAQ.
3.- Select one of the examples according to your needs.
If you want to send me your code and explain what are your needs, i can try to help you.
By the way, if you feel more confortable writing in spanish, feel free to do so!
I hope this information helps you, i wish you a great day! 🙂
(3,166 Views)
