Acquisition with usb-6008 in MacOSX (drivers daqmx base 2.0)
We are users of LabVIEW8 and USB-6008 in Mac OSX.
We want to acquire simultaneously or with the minimus delay as possible 2 analogical inputs.
What do we have to do to synchronize the analogical inputs?
Actually, we have the driver ni-daqmx base 2.0 for Mac, but we have seen that for the ni-daqmx 8 for Windows version there are some functions to synchronize the acquisition and to set-up the board that there are not in ni-daqmx base 2.0 for Mac.
Is there some function to do this in our Mac version?
What we need to synchronize the analogical inputs?
Thank very much in advanced.
Sincerely,
(2,817 Views)
As I answered you by mail yesterday, you only have to insert the two channels you wanna control into the physical channels input. Or into the task if you make it with the task assistant. Just introducing there all the channels you want to scan they are going to be sample with the configuration you insert.
For example in the phisycal channel name when you create the channel insert:
Dev1/ai0, Dev1/ai1
then you will have both channels on the same task.
jaime Cabrera
NI Applications Engineering Spain
Jaime Cabrera
(2,805 Views)
Thanks again,
Yezer
(2,780 Views)
