11-08-2006 05:14 AM
11-09-2006 02:46 AM
As I answered you by mail yesterday, you only have to insert the two channels you wanna control into the physical channels input. Or into the task if you make it with the task assistant. Just introducing there all the channels you want to scan they are going to be sample with the configuration you insert.
For example in the phisycal channel name when you create the channel insert:
Dev1/ai0, Dev1/ai1
then you will have both channels on the same task.
jaime Cabrera
NI Applications Engineering Spain
11-13-2006 05:33 AM
