Adaptor for a NI PCI-6221 board
I apologize if this the wrong forum to post this question.  Please move it if necessary.
I just ordered a NI PCI-6221, 37 pin DAQ board to replace an old one.  The old one has a different cord connector (non-37 pin) and has "connector 0 (AI 0-15)" printed on it.  Is there an adaptor available that will allow me to use my new board?
Thank you,
Jerry
(4,130 Views)
Sorry, the I/O connector of the old card is 68-pin VHDCI female and the new one is a 37 pin
(4,129 Views)
I have a similar problem with 50-pin DAQ card. You may want to look at using the connector block such as shown in http://sine.ni.com/nips/cds/view/p/lang/en/nid/204051. One end may be connected as screw terminals. You might find it less work for you if you use 68 pin connector block like NI SCB-68 (P/N: 776844-01) or CB-68LPR (777145-02) or NI TBX-68 (777141-01). One end of 37 pin cable wires would screw into the screw terminals of the connector block. Just my 2 cents after puzzling through connector maze.
(4,125 Views)
Hi Jerry,
I have been looking into this, but unfortunately I have not found a better solution than what bopja mentioned above with using the breakout board. It was my hope that you would be able to use  68-pin VHDCI to 68 D-Type then to a 37 D-Type, but this has yielded no results. Aside from using the breakout board you might be able to purchase each connector types and make your own cable.
Brandon L.
Automation Engineer
(4,117 Views)
Hi Jerry,
I was not aware at the time of my last post, but there is a 68 pin version of the PCI-6221 available. If you contact your Account Representative they would be able to discuss your options and possibly setup a exchange. Here is a link to that device. https://www.ni.com/en-us/shop/model/pci-6221.html
Brandon L.
Automation Engineer
(4,095 Views)
