03-17-2009 10:14 AM
03-17-2009 12:18 PM
Thanks for your quick answers, now everything is clear.
I'll check it asap.
Summarizing 3 ways of reading the onboard temperature:
1- DAQmx Calibration Info property node, instantaneous temperature in degrees Celsius.
2- DAQmx Create Virtual Channel using the instance AI Temp Built-In Sensor, can be continuous reading also in degrees Celsius.
3- DAQmx Create Virtual Channel using the instance AI Voltage, then the voltage has to be converted according the KnowledgeBase scale.
Thanks again,
Marc.
03-17-2009 12:53 PM
Marc,
To convert the voltage returned by the _boardTempSensor_vs_aignd for your M-Series device use the following formula:
Temperature in Celsius = ((-1 * voltage read) - 0.5) * 100.
It appears as though the reference knowledge base has not been updated for M-Series devices.
Dan
