Multifunction DAQ
Adjust DAQ voltage range in C
Hi
I am trying to run a USB-6211 in C++ and I wish to alter the voltage range from (-10V to10V ) to (-1V to 1 V). Can I simply change the minVal and maxVal in DAQmxBaseCreateAIVoltageChan call? Or do I need to adjust the device itself and recalibrate.
Regards
Simon
(3,038 Views)
Hi
Just wondering if anyone has thoughts on this issue?
(3,016 Views)
Accepted by zepp2
Hi Simon,
Thanks for your post. You are correct, you just need to change the minVal and maxVal in the DAQmxBaseCreateAIVoltageChan call. The DAQmx base driver takes care of the hardware from the range you select, you do not need to re-calibrate your device of adjust any of the hardware.
Ben B.
Applications Engineer
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(3,010 Views)
