12-10-2016 11:17 AM
Hello
I have an advantech USB-4704 data acquisition card. I've installed the requirements existed in its CD and the LabVIEW driver is also installed and it has been added to the list of modules in block diagram window, but I can't acquire data. When I add an "ADV AI Acquire Waveform.vi" block it needs to determine a device number and I don't know what to write for that. By using an arbitrary number (e.g. 0) and running, the error "The specified device does not exist or the device has not been configured using the Advantech Device Manager or AI Config VI." is shown. In the Advantech Device Manager window the Advantech USB-4704 doesn't have a cross mark on it but the add button is inactive and it can't be added to the installed devices.
I'll be thankful if you could help me.
Best Regards
12-12-2016 10:34 AM
Hi Esfahan,
When you say that you've installed the LabVIEW driver, which driver are you referring to?
I would be sure you have the most recent version of the advantech driver installed: http://support.advantech.com/support/DownloadSRDetail_New.aspx?Doc_Source=Download&SR_ID=1-IM07EN
I would also check to be sure that in windows device manager, the USB-4704 shows up, and is referencing the correct driver.
Since the error that you're seeing in LabVIEW is a user defined error(Advantech defined the error), I would recommend contacting advantech, as they would have a better understanding of what could be happening.
12-13-2016 12:46 AM
12-19-2017 06:11 AM
Hello.
Can I use the USB- 7404 card for The Biomedical Workbench ?
12-19-2017 06:35 AM
off course it could but best on your project may be it is not good solution
all depend on your project
