Analog Out on 6071E
I have the 6071E DAQ Card and there are only 2 AO channels on it.  I have SCXI 1000 with 1163 and 1326.  How is it possible then to have 5 AO channels on the module/terminal board if there is no multiplexing?  These 5 AO channels are controlling my motor and gas controller/meters.
(3,073 Views)
What 5 analog out channels are you refering to? There are no analog out channels on the 1163 and when I look at the manual for the 1326, I don't see any connections marked as A anything (which makes sense since it is intended for the 1162/1163).
(3,061 Views)
Oops haha I put down the wrong SCXI pair.  It is actually 1124 and 1325.  I am using 1163 for another purpose...to power 13 valves and relays.  Thanks for the help!
(3,059 Views)
Help on how this configuration can work?
(3,045 Views)
The SCXI-1124 is programmed serially by the DAQ device using a maximum of four digital output lines and one digital input line.
For more information on how the SCXI system works check out the Getting Started with SCXI manual.
Faris
Bueller
(3,019 Views)
