Analog Output not staying at programmed level SetAOIdleOutputBehavior vs. Buffer size
hav
I'm writing a function for a PXI-6259, which programms an output voltage on the analog output, but the problem I am having is that I have to write the value twice to the buffer for the output to stay at the programmed voltage, otherwise it is just a pulse value.
I am not sure if it is an issue with the buffer size, or the idle output behavior, although I expect the buffer size.
The write command currently looks like this.  Keep in mind the function is written in python:
def write(self, value):
samples_written = int32(0)
data = np.asarray([value, value], dtype = np.float64)
callc('WriteAnalogF64', self, int32(2), bool32(True), float64(-1), DAQmx_Val_GroupByChannel, data.ctypes.data, ctypes.byref(samples_written), None)
with the finite clocking looking like:
def configureSampleClockTiming(self):
callc('CfgSampClkTiming', self, 'OnboardClock', float64(10000), DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, uInt64(2))
I have already tried setting the buffer size in  configureSampleClockTiming to 1, and the same for the buffer in the write funciton, but that just causes an error.
I have also tried SetAOIdleOutputBehavior with DAQmx_Val_MaintainExistingValue, but this also creates an error:
DAQmxErrorAttributeNotSupportedInTaskContext                               (-200452)
any hints?
(3,134 Views)
Can you built in a short delay?
Maybe it's a timing problem.
(3,072 Views)
You shouldn't need to configure timing at all if you just want to update the value of the output to a constant voltage from software.  Pseudocode using the ANSI C function names:
//Initialization Routine (once at the start)
DAQmxCreateTask
DAQmxCreateAOVoltageChan
DAQmxStartTask
//Make this call whenever you need to update the voltage
DAQmxWriteAnalogF64
//Cleanup Routine (once at the end)
DAQmxStopTask
DAQmxClearTask
The minimum buffer size is 2 if you configure timing (I can't really give a great explanation of why, something to do with the read/write pointers not being identical).  Anyway, for simplicity I would just remove the timing configuration altogether (although you should be able to write the entire buffer with new data with just a single call... not sure why that's not working exactly--you might want to provide the entire sequence of DAQmx calls being made in order that results in the situation you are experiencing.).
Best Regards,
John Passiak
(3,057 Views)
