Analog Signal Acquisition with NI USB-6120
Hi there,
I am attempting to record an analog signal from a fiber-optic cable. The output voltage should vary with bending or compressing the fiber-optic cable. I'm sending 5V to the transmitter, then wiring the signal output from the receiver to the A0 input port. Typically, I then attach what I believe to be a ground signal to the A GND port on the NI board. When I do this, I record voltages around 1.2V, however these voltages are not very sensitive to bending or compressing the cable, and there is a good deal of noise. When I only use the 5V and A0 ports, however, I get a voltage closer to 5V that is quite sensitive to bending or compressing the cable. Could anyone point me in the direction of what I might be doing wrong? Do I need to be wiring the 5V, A0, and A GND?
Danny
(2,025 Views)
Some more information about setup would help.
What boxes do you have, how is it powered ...
How many channels do you need to read, at what speed?
Greetings from Germany
Henrik
LV since v3.1
(1,959 Views)
