Analog input current port for BNC 2110
HI,
    I am using BNC-2110 as an interface to connect to PCI 6280, I checked this interface card. I wonder if this curd can be used for measing input analog current (I mean directly). Does it accept input analog current?
   and one thing more, when I open Measurement & Automation module on my PC, I can not see the pinout layout of BNC-2110, I see some channels and a wierd pinout. do I have to map that pinout to BNC-2110 card? if yes, does anybody know how I can do that?
Best,
(4,969 Views)
Accepted by MiladAk
MiladAk wrote:Does it accept input analog current?
No.  You can use a current sense resistor though.  I = V/R.  If you measure V and you know R, then you can easily calculate I.
(4,961 Views)
Do you know about how to map BNC-2110 to the shown pinout of PCI6280?
(4,950 Views)
You don't need to map the pinout. The NI BNC-2110 acts as an extension for the PCI DAQ card, so it basically gives you easier access to the NI PCI-6280 pinout you saw in NI mAX.
Camilo V.
(4,921 Views)
Thanks, I got it 🙂
(4,913 Views)
