11-16-2009 02:38 AM
a short question about AO. I create a task, write the appropriate analog voltage to the line, then stop the task, and finally clear task.
After that all, the voltage level set on the NI hardware stays on the output. Is it normal? The question is, is it a normal behaviour, and I can use the AO this way, or should the task keep run/oper?
regards
Mitulatbati
Solved! Go to Solution.
11-16-2009 02:56 AM
