Analog output on USB-6009 - can I use DAQmxWriteAnalogScalarF64?
I just got a NI USB-6009 and I'm trying to use simple analog output.
I am running on a Mac, so I am trying to use the NI-DAQmx Base 3.2 C API (downloaded here: http://joule.ni.com/nidu/cds/view/p/id/1078/lang/en).  It is the most recent version of NI-DAQmxBase I've been able to find.
I am trying to do continuous analog output on the 6009, which does not have a built in clock.   So I was hoping to do the clocking in software, and just output new values whenever I want.
I can't seem to get basic data output to work.  From other posts and the Windows example files, (e.g. National Instruments/NI-DAQmx Base/examples/ao/MultVoltUpates-SWTimed.c) it seems that the easiest thing to do would be to use the function DAQmxWriteAnalogScalarF64.
However, this does not seem to be in the Mac version of the NIDAQmxBase C API.  There's actually an entry for it in the NIDAQmxBase.h file, but it is commented out.  Does anyone know why?  Is there any way to use this function for on-demand analog output on the Mac?
Thanks.
Chethan
(3,663 Views)
Accepted by topic author ChethanP
I have NI-DAQmx Base 3.2 installed on a 10.4.11 system.  One of the example files "genVoltage.c" calls DAQmxBaseWriteAnalogF64.  I've been able to compile and run this example with a USB-6009.
Would the  DAQmxBaseWriteAnalogF64 function work for you?
My guess is that since you can write a scalar value with DAQmxBaseWriteAnalogF64, DAQmxBaseWriteAnalogScalarF64 becomes redundant.  The example that came with installation shows how to write a single value (i.e. scalar).  I pasted NI's code below.
int main(int argc, char *argv[])
    // Task parameters
    int32       error = 0;
    TaskHandle  taskHandle = 0;
    char        errBuff[2048]={'\0'};
    // Channel parameters
    char        chan[] = "Dev1/ao0";
    float64     min = 0.0;
    float64     max = 5.0;
    // Timing parameters
    uInt64      samplesPerChan = 1;
    // Data write parameters
    float64     data = 3.25;
    int32       pointsWritten;
    float64     timeout = 10.0;
    DAQmxErrChk (DAQmxBaseCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxBaseCreateAOVoltageChan(taskHandle,chan,"",min,max,DAQmx_Val_Volts,NULL));
    DAQmxErrChk (DAQmxBaseStartTask(taskHandle));
    DAQmxErrChk (DAQmxBaseWriteAnalogF64(taskHandle,samplesPerChan,0,timeout,DAQmx_Val_GroupByChannel,&data,&pointsWritten,NULL));
Error:
    if( DAQmxFailed(error) )
        DAQmxBaseGetExtendedErrorInfo(errBuff,2048);
    if( taskHandle!=0 ) {
        DAQmxBaseStopTask(taskHandle);
        DAQmxBaseClearTask(taskHandle);
        printf("DAQmxBase Error: %s\n",errBuff);
    return 0;
Hope this helps!!
(3,643 Views)
It does help, thanks!  I was having trouble using the DAQmxBaseWriteAnalogF64 function, but I was basing my code off the contGeneration.c file, which is setup for a different device.  I probably just didn't change all the settings correctly.
But I can now base my code off of genVoltage.c, and it should have the functionalityI was lookingfor with WriteScalar.  Excellent.
Thanks for the reply!
(3,637 Views)
