07-11-2006 07:16 AM
07-12-2006 05:14 AM
07-12-2006 05:23 AM
Sorry for the confusion, let me try to explain further:
I have 42 10kiloohm pots in parallel, and I need to produce a 10V reference voltage for them. This is so that the voltage across the potentiometers can be measured using the analog inputs of my SCXI 1102B.
By my calculations (using good old V=IR) the 10V across the pots will require a drive of around 42mA, whilst the DAQ card appears to only drive 5mA. I was wondering if someone could confirm that this is correct, and so confirm whether or not I can use the PCI 6221 to drive the 42 pot configuration described
Many thanks
John
07-12-2006 12:04 PM
