Analog read, external clock USB 6009
I am trying to program a very simple task but I fail and wonder if anyone could help me?
I have a NI USB 6009, which I program with C and use Visual Studios C## 6.0
I want to create a program:
              On every TTL-signal coming in to the 6009, reads an analog value comming in to the 6009. It should not be that it starts to read on the first signal and then reads all samples at once. Instead it should read everytime it receives a TTL-signal.
(2,993 Views)
Hi
Looks like this is an accidental post since there is a longer post that starts exactly the same posted 10 min later here
Regards
David
NISW
(2,973 Views)
